EFIS-D60
If you're seeing non-zero roll, you'll need to correct that in the mount. There's no adjustment for that. If it's pitch where you're seeing issue, use SETUP > PITADJ to get the zero pitch value correct.
abedinpour
hi,
i tried to adjust it by adjust remote compass module but nothing happend (heading was moving but not roll ), do i need to adjust mount EFIS-D60 itself or something is wrong with the remote compass?
EFIS-D60 looks like doesnt have any room for adjust
The remote compass adjusts only heading, not pitch and roll. The sensors for pitch and roll are inside the screen.
If you have that image while you believe the actual EFIS unit is perfectly level, then it needs to be repaired.
Just an observation here -- with aircraft that have 'curved' panels, ie Jabiru & Lightning etc I usually make sure the wings are level first (digital level & wing jacks) then make a level line on the panel for a reference point. ;)
HTH
Jake J
