EGT/CHT reading high after installation
PeterThomson
Thailand
Help ! I have just installed a D180and all the probes in a Jabiru 2200 and when the D180 is powered up, all the EGT/CHT are reading high (like 100's and 1000's) on a cold engine.
What have I done wrong?? :-[
When the CHT/EGT harness isn't actually connected, you'll see those values "float", in which they'll be all over the place (and different). Any chance the whole 25 pin connector isn't actually connected?
Else, if the 5V line is going somewhere it ought not to, then that can affect everything in the unit.
PeterThomson
Thailand
No problem with plug or 5V. line.
However, we found that, when running on the internal battery, all was normal.
A direct (fused) line from the battery also gave normal ops.
Evidently the 12v. supply from the main bus is causing the problem and we are now hunting this down.
PeterThomson
Thailand
The problem was that we ran the line from a single sender to both the original VDO gauge and to the D180. This caused the reading error on the D180 (and probably the VDO too).
Is there a fix for this, other than using dual station senders if we wish to use both D180 and VDO ?
thanks
Peter
There isn't an easy way around this to have both gauges be active and accurate simultaneously Actually, even if there were, what looks like redundancy is actually a liability. If EITHER instrument should fail, the circuit may change, and then the remaining gauge is likely to be affected in some unpredictable way depending on the nature of the failure.
For some gauges, switching just the output line between a gauge and the Dynon may work well. This will only let one work at a time, but, in the event of a failure of the active gauge, a switch can flop the signal over to the other device.
This author's personal take, though, is that unless you have an exotic engine that will blow up if you're not watching some parameter (maybe old manually-controlled turbocharged engines? I'm not an expert on exotic engines), should you lose ALL engine gauges, you still have your ears and your throttle hand; the engine keeps on spinning; you're not looking at a full-blown "need to get down in any corn field" emergency. Basically, an instrument isn't critical for continued safe flight, think about whether the added complexity of making such an instrument redundant is the right choice.
