Electronic International probes with Ems
Mzwijacz
I have an existing aircraft that I'm upgrading to Skyview. The aircraft is currently flying regularly and am building the new panel on the bench. My current engine gages are all Electronics International (EI). I'm trying to figure out if I can reuse all my existing probes.
Currently have :
Engine Monitor UBG 16
Fuel Flow FP5L -Skyview uses EI red cube fuel transducer
RPM R-1-4
Oil Temp/Pressure OPT-1
Volt/Amp VA-1A-60
The documentation doesn't say anything about if the probes are J or K type, so I can't say. Has anyone made this conversion before and will the existing probes work with the EMS module ?
Thanks,
You can use your fuel flow, RPM, EGT, CHT, and voltage sensors for sure.
What you listed was the part numbers for the display gauges, not the senders. So I can't yet tell if you can use your oil temp, oil pressure, or amps senders. We need the original manufacturer part number, not just what they sell them under.
Mzwijacz
Thank you, I will need to pull the cowl this weekend to check those sensor numbers .
The amp guage is connected to the shunt. It is at least 25 years old. I have no idea who it was made by. I don't recall any identification on it.
Thanks,
