Best way is to use wire 6 from the E-MAG to the EMS rather than using the p-lead (wire 4). Wire 6 is made to supply a pulse to an EFIS. You don't need the resistors mentioned in the Skyview Installation manual.
The left E-MAG wire 6 is connected to EMS pin 32 and the right E-MAG wire 6 is connected to EMS pin 33. You really only need one wired to the EMS as the pulse doesn't stop when you ground the p-lead. The E-MAG instructions recommend only connecting one E-MAG, but the Dynon is made to use both connections. I used both connections.
You also need to set the pulse to 2 in the Skyview setup. In the Skyview SETUP MENU, go to EMS SETUP > ENGINE INFORMATION. You can set the pulse there.
Good choice of electronic ignition.
I've put a couple hundred hours time on mine. Made a big difference in starting, performance and fuel economy.
