EMS 37 Pin # 15 12V AUX
rockyjs
Navarre, FL (AL55)
Can the 12 Volt Aux located on the EMS 37 Pin 15 be broken out similar to the +5 volt excitation?  I'm using it on fuel flow, but would like to add another max 200 MA load to it in conjunction with the Flowscan fuel flow sender.
You can split it for other uses, but you can't put 200mA on it. It has a 50mA fuse.
