EMS - D10 Fuel Flow
stephen_vestuti
Hi,
I am assessing what to fit to my Europa build (panel wise ).
The Rotax 912S fitted to the Europa has a fuel flow line
and also a fuel RETURN line, I will be fitting two fuel flow
sensors which both need to be connected to the EMS - D10 in order to differenciate the flow total -
I can only see one input on the spec. sheet of the D10 - is that correct ?
If so , will there be an upgrade in the future ?
Steve.
The EMS-D10 does not have a second fuel flow input. But, you can use an external box (not made by Dynon) that does the subtraction between two flow sensors and outputs a single signal. There are two known modules out there that should do the trick. See http://wiki.dynonavionics.com/Parts_not_supplied_by_Dynon for more details
