Am close but have some last questions:
1. I have a composite panel. Got the 14g wire to ground the case but I'm told that anodizing isn't good for grounding and the case is anodized? Where to attach wire - maybe a mounting screw?
2. What do I gain from connecting to GPS? My D10 EFIS already is.
3. Where does the yellow wire (pin 2) connect to?
4. Am not clear on what to do with pins 11, 12 and 30 to connect to my laptop.
5. Which of the three is the most common way to install the Ammeter Shunt?
Thank you!
Thank you!
