My EMS D10 has several problems that beg correction. The application is
an O-235 Lyc in an experimental Cub.
1] The resistance fuel gages will not accept the incremental fill
calibration. I checked the resistance prior to the installation and the
pots yielded good linear resistance values. I have two wing root tanks
with the pots installed in the but of the wing close to the fuselage that
will be difficult to remove. My fuel flow system reads correctly but
with 24 gal tanks in a O-235 Cub I rarely fill the tanks and fear a
cumulative error using strictly the flow system.
2] The RPM reading off the P-mag has become intermitently eratic.
3] The manifold pressure reads 57" but I believe it was accurate for the
very early flights. I have your OAT installed and reading but w/o the
manifold pressure the % power feature is inoperative.
I would say that I should send the unit to you for a compelete
evaluation. Please advise me of your thoughts on these problems.
