Ems fail after V16 update.
russp
Did the version 16 update and now display is simply showing Ems fail on the engine display. Skyview HDX 10inch Rotax 912iS. Did the update with the system software update at which point I got the fail message, loading the sensor update didn’t fix the problem 😒 any ideas?
Stevec
Look back at previous instances of a network devices not coming online. The fix works for most.
Stevec
Here’s my reply to previous post.
Just to add to the previous post. If a network device is not coming online Dynon suggests unplugging that device from the network. Power up and run the configuration again. Power down and plug the device in again. Power up and rerun the configuration again and it will then add the new device. It appears it is a known problem that they are looking into.
steve
