EMS has red X when pressing PTT
preid
SoCal
Moved from separate thread to address this issue
Friend I am using D1000 .and EMS module and for warning light on display I am using LM 7812 voltage regulator .today I feel that when I press PTT whole EMS page showing cross.can you help me
preid
SoCal
You are receiving red Xs means there is a short and a call to Dynon.
There has been issues of the EGTs spiking when pressing the PTT and that was resolved with a updated/replaced EMS unit.
preid
SoCal
In that case send note above to Dynon support for troubleshooting at their level
Akash -
What aircraft hull material type ?
Where is you Com antenna located in relation to the EMS unit ?
What type of antenna coax cable are you using ?
note - if you are using a recently purchased EMS unit then the 'issue' would normally be elsewhere, answers to the questions may be very helpful.
Akash
Ok friend finally my problem was solve .12volt dc voltage regulator power lead is touching with ground wire.lots of thanks
