Two Questions on installing my EMS-D120 on my Jabiru 3300:
Jabiru indicates that I can pickup the tachometer signal from an alternator output or from a $50 pickup next to the flywheel. Do you have any recommendations based on experience as to which works better?
and
I need an AN fitting for the fuel pressure sender. It should be female 1/8 inch NPT for the sender on one end and a 1/4 inch ID hose barb for the Zenith supplied fuel hose on the other. Is there such a fitting?
thanks .... Jeff Davidson
and
