B.Blenden
My problem appears to be only with the oil temp widget, only on the 50% EMS screen. The problem first appeared when I moved the widget. A gray image of the widget remained in the old location with a red X overlaid. The widget in the new location seems normal. I tried removing the widget, but it just removed the relocated "good" widget only, which I restored with no problem. The other EMS display screens (100% & 20%) are normal and the oil temp widget appears normal. To summarize, the 50% EMS screen now shows two oil temp widgets, one normal and one grayed out with a red X.
Update: After talking with Dynon Tech, problem solved. In the EMS sensor setup there are two oil temp widgets. The guilty one is at the bottom of the sensor widget list labeled "oil temp(can)". I "removed" that widget and the gray widget disappeared. Apparently that is for a serial connected oil temp sensor. Hope this helps others with same problem.
