ems sensor  error
philcie
i just finish to install the D180 with a cont O-200
all sensor from dynon
the problem is
on a cold engine
ACTUAL local TEMP 68 F
but on the dynon I read
all cht 251 F
all egt 254 F
Oil temp 104 F
Carb temp 55 F
Oat 11 F (alt -2570 Ft)
and oil press show "---" in red
on running engine
egt and cht going up
and all other sensors  don't move
oil press still red "---"
tach working
any help for those problemes  :-/
i check all grounds from db37
sincerly
philippe cie
Check the routings of the 12V and 5V outputs from the EMS DB37 pin harness. If they're shorted or going somewhere they shouldn't, you can get some erroneous readings across a bunch of different sensors.
