EMS setup for Rotax oil temp
Mazerbase
I have a Rotax 912ULS and the EMS has a warning when the oil temp is below 120 on takeoff power. I want to adjust the temp down for the warning to 100 as I don't have the turbo and I have been advised 100 is adequate. I have about 800 hrs in Rotax powered airplanes so I am reasonably confident about my choise. When I go into EMS setup and try to adjust the sensor, the SV says Rotax oil temp (fixed). Anyone have a workaround?
The "Rotax" engine pre-sets add dynamic redlines, but its prescription, which was based on the documentation available at the time of that feature's development, may not be ideal for all variants of the Rotax engine. If it isn't right for your engine or preferences, you can select the "other" engine types, and those behaviors go away.
