I am working on installing the potentiometers for the trim servos and the flaps position sensor (Ray Allen) I am using VPX, and slightly confused. Stein built my panel and included 3 wires for the flaps position sensor from VPX, according to the manual i am supposed to used Black Ground Wire = white blue wire - Wire 4, 6, 7, 8, 9, 10, 11, 12, 20, 21, 22, 23, 31 = White Green (Signal Wire), White Red Pin 18 (5V) = White Orange (Power Wire).
Question 1: Can i use red wire Pin 15 (12V) instead, i already have pin 18 hooked up to 3 sensors in the engine area?
Question 2: If the answer to 1 is NO, then what is the best way to splice into it towards the 37 pin connector under the panel or towards the end of the wire and run the power back to the main cabin?
Question 3: In addition to the 3 wires coming from the VPX that stein built, do i also have to connect the above wires to the ray allen flap sensor to get it to show on my HDX screen or do you think that the 3 wires from VPX will work?
