nearwater5
- Joined
- Jul 19, 2009
- Messages
- 4
While flying today, the EMS switched itself off and then restarted immediately with no obvious changes to the display. Initially it happened about 10 minutes apart, but after an hour or so, it started happening a minute or so apart. EMS and GPS are on the same power supply, but do not switch off.
I had some trouble a while ago with the MAP sensor when I wired it back to front. I rectified the wiring, but the MAP doesn't display as it should, it just reads ambient pressure (with some fluctuation happening). This I am not concerned with unless it is causing the power outage problem.
Also the Tacho is reading correctly, but does tend to fluctuate a bit up and down. Doesn't seem to be related to the power outage when that occurs. Voltage is showing about 13.4 volts and the current shows about -3 amps when flying.
Not sure where to start, would appreciate some guidance.
Thanks, John
Thanks, John
