EMS Warning Light
RICHAWK
uk
I am not clear on the function of the warning light output on the EMS D37 pin 29. Is the output switched when any alarm condition is reached ? does the output switch to +12v or ground ?
Richard
It is not currently active in software.
When it is, it will switch to ground when an alarm condition exists. It may also flash at times depending on the alarm.
The output is "open collector" - it's hooked to nothing when off and ground when on. You hook your light between it and a positive voltage source.
