EMS wiring
TRCsmith
Suisun City, CA
1. Can the wires/leads from the CHT & EGT be cut and pinned for exact length to the EMS module
2. Also the same for the EMS harness to the SV system?
My question in general is can all the wires be cut and pined or re-pinned to an exact length to reduce extra wire bundles?
I will also be ordering a network hub.
Thanks Tom  ::)
If so, do I need to order extra pins?
1/2) Yes.
We don't sell the extra pins, but if you call our tech support at 425-402-0433 they can get you set up.
Also note that the SkyView network harnesses are in 3/6/10/20' lengths, some of which don't have both DB9 connectors connected so that you can route cables through tight spaces before you connect the DB9.
