terciops
T51 baby Mustang / Two Main Tanks - 28 Litres each / Princeton 5 point Capacitance senders / Type 2 / Global Set to 2 tanks etc etc...
I get 501 as a reading when the tanks are full and I am looking at the start screen for a tank calibration. I put 35 litres for the tank capacity and during the calibration of the tank I see the numbers go progressively to 245 ish at 20 litres. Then everything stops increasing even if I add more fuel to full.
I answer YES when the system detects no increase in value and the calibration complets and I am left with a 20 litre FULL reading. The tank guaging is perfectly OK up to 20 L but above that it just reads 20 (of course since that seems to be its' version of full).
My query is... When it asks for tank quantity at the start of the calibartion run is this the tank you are working on or a TOTAL capacity.
I have been reading it as just the ONE tank, but these results make me think I should be putting in the TOTAL tankage as this may be why it is maxing me out at 20L per side.
Thoughts please before I get brain damage from do this over and over to the same result and breathing is all the petrol fumes.
Madness is after all define as "Doing the same thing again and again and expecting a different result"...
Ken
Ken
