Hello,
I was doing a power up of my d100, and ems 120 + hsi34 all together, and all was fine during about an hour. I use an power supply of 20vdc, well in the spec. None of the instruments are on the plane yet, and the were never really used, despite being 2 years old....
only power supply and dsab bus are connected. After an hour or so, the d120 turned into a brick, black screen, and is no longer present on dsab bus. D120 and hsi34 are fine.
When I power up the d120 alone, I see the blue dynon welcome screen, then the device screen get black, and there is a single small clik ( relates to amps / current calibration, If I do recall) . nothing else after.
Should I : try to reload firmware 5.2 ( the one already in), then , if nothing works, send the ems 120 back to you? serial of ems D120 : 2067
Regards!
Regards!
