EMS220 and Skyview battery reading 0v
ma1owens
Kent WA
The original installation had the Battery Widget working properly then it changed, I have not been able to track down why. My skyview is now displaying 0v for my battery reading.... I checked the continuity. EMS pin1 to Battery, it is shows connected and then using my meter it shows 12v. I reconnected the cable to the EMS and restarted they Skyview system and it still shows 0V.
Are you sure you're getting that 12V at the connector? IE, where are you measuring? There's also an EMS sensor debug menu under the EMS setup that will show you what the EMS module is actually outputting.
