Engine cooling pressure
bbtapb
Hi.
I'd like to add a cowl differential pressure (top vs bottom) sensor. Lycoming says I should have about 6" water difference. Would this sensor do the trick? And, if it's not too much to ask, an SFG file entry? Thx.
http://www.digikey.com/product-detail/en/freescale-semiconductor-nxp/MPX5010DP/MPX5010DP-ND/464054
  • MPX5010.pdf
kurtfly
Bob,
This looks like it will work. It outputs ~0 to 5V, but it requires 5 volt excitation. So you will have to get that from some place. Needs to be mounted, designed for a Printed Circuit Board. Calibration is no problem.
If your not planning on installing this permanently then there are easier alternates. An airspeed indicator is a differential pressure gauge. Pitot to the high side, static to the low side. Just need to convert airspeed to PSI or Inches of water.
kurtfly
Bob,
For the MPX sensor you provided the calibration is y = 0.112119x + 0.200000 to give EU's output in "Inches or Water".
So create a new sensor definition like:
sensor={
id=MPX DIFF PRESSURE
;UN-VERIFIED
function=PRESSURE
pins=C37_P8 C37_P22 C37_P23 C37_P31
name=DIFF PR
min_val=0
max_val=40
resolution=0
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=.112119
c_x0=-.20
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high_resistance=NONE
high2low_cross=0
window=.2
shift=3
age=16
kurtfly
Bob,
Sorry I had an error in my calibration calculation.
Should be y = 8.919080x - 1.783816
sensor={
;UN-VERIFIED
function=PRESSURE
name=DIFF PR
min_val=0
max_val=40
resolution=0
round=.1
is_piecewise=0
low_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=8.919080
c_x0=-1.783816
low_resistance=NONE
low2high_cross=0
high_coeff={
c_x4=0
c_x3=0
c_x2=0
c_x1=0
c_x0=0
high2low_cross=0
window=.2
shift=3
age=16
bbtapb
Thanks!
Found this even more convenient.
https://www.widgeneering.com/mpx5010dp_freescale_pressure_sensor_with_carrier.html
This over an ASI because I want it in the data log.
dougnlina
So I am using this sensor and trying to set it up for inches of water to be displayed on the EMS. I have used the formula as shown in Reply 4 but am getting readings that are not accurate (as compared to an actual water manometer) When I work the equation (limited skills using Excel) I get Kurts coefficients from Reply #2. I have not tried these numbers, but Kurt, I am wondering what "mistake" you found to change the coefficients? I'll report back if the original formula matches the manometer...
kurtfly
From the vendor data sheet provided in original post we have:
Pressure Range of  0 to 1019.78 mm H2O, convert this to Inches.
mm to Inches is 1 Millimeter = 0.03937007874 Inches.
So, the new pressure range is 0 to 40.14881889 in H2O.
The sensor has a full scale output of .20V to 4.7V (4.7-.2=4.5).  So the slope, C_x1 is 40.14881889/4.5 = 8.92195975.  This is 8.92195975 inch H2O per Volt.
The offset, C_x0 is the sensor offset.  The datasheet shows a typical .20Vdc offset at 0 inch H2O.  This make the c_x0 term (.20 *8.92195975) = 1.784391.  This needs to be subtracted so it makes it -1.784391.
I do not have the original math I used, but I believe I used sensor 1.45 PSID as the starting point and converted to In H2O from that.  Rounding errors.
With 0 pressure applied to both ports, the display on SV should be reading 0.  You can connect a tube between the two ports to ensure no difference.  If it does not you can add/subtract from the C_x0 term to force it to read 0.  this is due to the sensor Minimum Pressure Offset of 0V to .425V, typical is .20V.
I have attached a simple excel spreadsheet that performs the math if you prefer.
  • Calibration_Calc.xlsx
