My number 3 has gone nuts. Negative values, then reading right, then the next second 800 degrees below the rest. There is no problem with the engine I am quite sure, so it must be a wiring issue.
I have 120 Hours on the plane and this just started. Per one of the threads here, I pulled the Dynon 180 and unplugged the appropriate plug to recrimp the connection, but it is a factory plug and I don't think I can just "pull" a wire and recrimp it. Even if I could, the 180 install manual does now show which pin is the #3 EGT.
The cowl is off and I am doing my annual, so I double checked all wires going to #3 and they all look OK.
Any ideas?
Any ideas?
