Right now, the engine is running rough, since I am in the initial programming stages. But, when I run the engine to 2,000, the tach bounces between 2,000 and 1,400, faster than the engine could change. It does this when I select either left or right tach operation. It seems to work fine an lower RPMs.
I am using both right and left tach inputs to the D180. For RPM right, I have a 30K ohm resistor between the mag switch and EMS pin 33. (Slick 4301)
For RPM left, I have tied to a fuel injector +12V line. In normal operation +12V is always supplied to the injector. To pulse the injector, the +12V grounds through the EC3 ECU. I have a wire tied in, between the injector and the ECU and it connects to EMS pin 32.
Any idea how I might proceed to eliminate this bug?
Sam
Quickie Q-200
Sam
Quickie Q-200
