External EMS Warning Light
TJRV8
Wired the light per page 7-51. Trying to complete the EMS sensor mapping, but pin C37 P20 does not show up. How/ where do I insert C37 P29?
Terry
It's not a sensor input, it's actually a switch to ground functionally. You don't need to use the pin mapping to configure it - it's always, during an alarm condition, sending that pin to ground, causing current to flow through the lamp, regardless of whether or not you have a light connected. So if it's hooked up correctly it should work when an alarm goes off.
