Failure on tachometer, Oil temp installation, help
Vingman
Hello !
I'm the owner of a D180 with both EFIS and EMS. When i installed it i used the original wiring harness, and the other contacts i have made on my own. When i use the D180, the tachometer works fine on "power", but then the Oil Temp and Oil Pressure is wrong. When i switch to "battery power" the tachometer shows 0 and the Oil Temp and Pressure is OK,
Anybody that has any suggestions to solv this problem.
The engine i have it installed on is a Jabiru 2200, and it has only been running 140 Hrs.
Best regards
Vingman, Norway.
