Feature Suggestion EGT Display
Dynon101
I love flying!<br />
It seems the feature suggestion sub-forum has gone away with the switch to the new forum hosting site.
I will post my suggestion here...can you provide a way to divide up the EGT display so that odd cylinders can be placed on one side and even cylinders on the other side.
Some airplanes are tractor and some are pushers so it would be best if the user can select "odd cylinders on left" or "odd cylinders on right"
You can definitely do this, but it does require that you re-pin the EGTs and CHTs on the connector. In other words, you could cluster your left cylinders in the 1/2/3 slots, and your right cylinders in the 4/5/6 slots. SkyView doesn't do anything clever with the cylinder/EGT positions, so you can pin them however you want them displayed visually.
Actually I lied. The pin mapping in the software setup has named slots for each of the CHTs and EGTs. So you can just rearrange them there (by choosing which actual CHTs and EGTs you want to be 1-X. So no rewiring required.
