File with Fuel Level Calibration Numbers?
Marc_J._Zeitlin
Tehachapi, CA 93561
Sigh. I've checked the "Sensor Config" and "User Config" output files to find the table of "voltage vs. fuel quantity" numbers, for a capacitive sender but no joy.
Where the heck is that information stored? I can edit the table on screen, but on screen doesn't allow for inserting an extra data point (which would save a whole new calibration run, and 28 gallons of gas).
Thanks!
You might need to save files before and after editing the table, and compare them.
tylerpattison
0x44 0x59 0x4e 0x4f 0x4e
It's in the .dfg file. Try searching for "LEVEL" or "user_cal". You are looking for something like this:
user_cal={
valid=1
name=LEFT LEVEL
num_points=8
point={
volts=1.24756
value=0
point={
volts=1.57764
value=2
point={
volts=1.88725
value=4
point={
volts=2.1582
value=6
point={
volts=2.36206
value=8
point={
volts=2.54761
value=10
point={
volts=2.67822
value=12
point={
volts=2.72095
value=12.5405
