Flap position and Landing gear warning
Researcher1
Hello,
Is it possible to configure the SV-D700 to give a warning (with suitable micro-switches installed) when the the wing flaps are extended beyond the maximum approach flap position, using a normal landing procedure, if the landing gear is not fully extended and locked?
There's a specific gear warning feature that you can read about in our installation and users guides (short version - you get a callout that says either "check gear" or "gear overspeed" if you're in a suspect configuration as you slow down).
You can also alert ANY item based on a contact input, but there isn't a way to make them conditional on airpseed. So basically, no to the first question, but yes to the second.
Researcher1
Thank you for the reply, is it possible to make it conditional to throttle position? the same was that the "check gear" warning is?
