Flap position
avtech1959
I am using a Van's Flap Relay ( ES flap control board) on my RV8. Is it possible to see flap position on sky view screens. I am using two 7" screen. If possible had do you wire it.
I'm not familiar with that product. If there's a position sensor output, then yes. What part number is it?
The position output is internal so unuseable however adding a Ray Allen POS-12 sensor will give the output needed to display position on the Dynon.  The FPS can still be used as planned as well.
Ps - IF you are using the VP-X system then do not use the FPS if you want the Vp-x Flap features.
Jake J
