Johnh38
I’m having a problem/issue that I can’t seem to figure out in setting up my Flap sensor readings on Skyview widget screen.
I have assigned the pins on the EMS sensor settings page and am now trying to calibrate the widget under EMS Flap Calibration page.
I'm using the Ray Allen POS-12 position sensor wired as follows:
RA Wires EMS Wires
White/Blue Black (gnd) (Sharing connection w/Trim Servo)
White/Orange White/Red (Sharing connection w/Trim Servo)
White/Green Violet/Yellow (Pin #22)
Here is the issue.
The sensor voltage when the Flaps are level with ailerons is 0.00 volts
As I continue to hold the flap switch down, the sensor voltage goes steadily up until it reaches 0.62 volts (approximately the mid-point of travel downward.) As I continue to keep the switch pressed down, the voltage begins to reverse direction, 0.62.0.59, 0.32...etc and approach 0.00 volts. The flaps are now at ~ 40 degrees (maximum downward deflection), but sensor voltage is back to 0.00 volts ???? Why the change back to zero? The EMS tells me that there hasn't been a change do I want to continue? Yes or No. I've tried saving it, but the widget is all screwed up when I do this.
I am not using a VP-X but am using an intelligent flap controller http://www.tcwtech.com/Installation instructions model IFC-10_rev1.1.pdf. What's stopping the voltage to continue to say 1.24 volts? (double the 0.62 volt value) This swing in voltage has me stumped.
Any help would be greatly appreciated.
Thanks,
john
RA Wires EMS Wires
Here is the issue.
Thanks,
john
