I recently built a flap sensor in my RV-8 using a round potentiometer which I installed an arm onto the shaft. Then I connected a stiff wire (piano hinge wire, actually) down to the end of the flap actuator. Did you ever get your system working? If not, I can send you some photos of how it worked out in my RV-8. Of course, your geometry is different in the 7 so it may need some more engineering. But mine is working great, so if you need some more ideas, give me a shout.
Rich, N707RW
richwilson "at" cfl dot rr dot com
