FLickering lines on display and low MAP reading
Fly4funn
The long awaited day has finally come to power my panel up. I have a Flightdek-180, a D-100, HS34, and AP74 with servos. Panel is wired to a GTX327 and SL30 although neither of those units are installed in the trays. I have 2 issues with the unit. There are multiple lines, sometimes 2 or 3 and sometimes 10 or 15 lines that flicker across the screen. The D-100 does not have this problem. It is random, sometimes only seconds apart and sometimes it almost seems like it isn't going to happen again. Nothing I do seems to make it better or worse.
The second issue is that the MAP is reading 7.2. I'm at 200MSL so I know that is not even close right. Engine is not quite ready to start so all of this is happening when the it is just sitting in the hangar. All else seems to be OK although temps and pressures can't be checked yet.
Any ideas where to go with this? :-? Firmware has just been upgraded to the latest version available.
Thanks!
Thanks!
Fly4funn:
These kinds of issues are more effectively handled by working directly with our tech support department- email support@dynonavionics.com or call 425-402-0433. We have two full-time tech support folks available to work with you.
