Flight Director
N927BC
Mukilteo, WA
The flight director cannot be preselected for take off and it is very unfortunate. Presetting heading, altitude and rate of climb or airspeed is very important when flying IFR which is when one needs the flight director. When the flight director is set on the ground prior to take off when the airplane starts to roll for take off the flights cues disappear.
Bob,
We'd love to have this too. But we've never quite figured out how to make it work safely.
In order for the FD to assist in a departure, the system needs to have a set of rules to get you off the ground. In airliners, generally this is a specific pitch angle and zero roll hold until a specific distance off the ground, and then a transition to the various pilot commands. These systems also generally have a good way to know when you are on the ground or not.
Without this, if you turned on the FD to a heading 10 degrees off runway heading and 4,000' above the plane, the command bars would peg to the side and down until you were airborne, since your airspeed is low. It would do this until you got to a minimum airspeed, and then it would still be wrong on the climb-out when you should be in airspeed or pitch hold and have zero roll.
This is why we have preferred our implementation. You can pre-select headings and altitudes, but you need to wait until you are airborne to engage the FD. That way we don't give incorrect and dangerous commands to the pilot on roll out and initial climb. If you do turn it on, we turn ourselves off to prevent misleading cues.
If you have an example of a GA AP that does a good job of departure commands, we'd be happy to look at it and see how it deals with the issues and how the UI works.
N927BC
Mukilteo, WA
I think if prior to taking off the flight director could be armed in roll mode only and a positive pitch mode of what ever the default climb is set until the auto pilot speed floor is reached would be a good fix.
