Flight Path Marker
flybuddy
fort myers, florida
I have noticed in flight that the Flight Path Marker always seems to be off to the right side (straight and level with ball centered). Is it possible that my ADAHARs needs realigning horizontally?? I've only had 3 flights since install with minimal wind. thx Tom
Fundamentally, it means that SkyView thinks you're tracking to the right of where you are pointed. This probably means that your magnetic heading is slightly off. Could be a slightly misaligned ADAHRS, though if you haven't gone through the calibration process yet, start there. If you have an uncommon GPS, it's also possible that it's outputting true and not magnetic heading, and that will cause GPS track errors by the mount of the magnetic variation for your location (varies around the US) It's important that the ADAHRS be straight though, so don't rotate it in yaw to fix the heading: that will adversely affect the attitude indicator.
