Flight Plan waypoint entry question
How do you want to enter Waypoints
  • Total voters
    0
dabear
Warrenton, Virginia
If you are in the flight plan (but not in the menu) and you move the knob to the right, you can put in a saved flight plan.  I've never used the feature since I always manually input the flight plan on the ground or in flight.
The flight plan menu requires that you enter the menu and then scroll to the "enter waypoint" choice and then move the knob to the right. You are then able to enter a waypoint.
I recommend that either we ask Dynon to change it to default to enter a waypoint and use the menu to enter a saved flight plan.  OR allow a setup configuration to set the default between the two.
Thoughts?
So there's another way that's simpler. When you're looking at a flight plan, just press INFO, then spin in the waypoint ID, then press ADD>FPL at the bottom of the screen. In fact, the FPL MENU > INSERT WAYPOINT probably ought to go away. I think it's a remnant from an earlier incarnation of the map interface.
Does that get you what you're after?
