FlightDEK D180 EMS D120 data share
TOMARK
Hello
I have a problem whit sharing EMS data that is displayed on the FlightDEK D180.
I have installed the FlightDEK on the pilot side of tha plane and EMS D120 on copilot side. And I need to D120 be showing(reading from flightDEK) the the same EMS data that the FlightDEK is reading. I tried to connected it trouhg the DSAB A and DSAB B connection whit no success.
Thank you for your help.
Robski
Hang on! I've got an idea!
Do you really mean you have a D180 on the left and a D120 on the right, DSABed together? :-?
I don't think that is a supported configuration.
I believe you can only have a single EMS device in a configuration.
I guess you need to ditch the D120 and replace it with a D100 or D10A.
Rob is correct. A D180 and D120 together cannot share EMS information. If the device can do something locally, that data always comes from the local device.
The most inexpensive change in your case is to replace the D180 with a D100, and sell the D180 for more than the D100 cost. Then either screen can show either set of data.
Robski
Doh! Should have thought of that - it's the basis of my RV's setup! ::)
