T
Thomas P. Swatloski(Guest)
I am building a Helicycle and would like to use your FlightDEK-D180 as the primary instrumentation for my helicopter. The Helicycle uses a small turbine engine for power. Could the display be changed to show Engine RPM and Rotor RPM instead of MAP? The turbine has need for only one EGT. Could the extra EGT and CHT screen space be reprogrammed for gear box oil pressures and temperatures? Maybe even add chip detector display?
