C
canardflyer(Guest)
Flowscan fuel flow sender installation has not gone as smooth as all else.
I installed the sender unit in the un-pressured section of the fuel line. Configured it 'on' and set the proper K-value
Upon power up and engine run it read zero.
I checked the wiring. EMS pins 13 (gnd), 14 (signal), 15(power). I saw no power on the pin 15 (red) wire - was expecting 12V. To ensure that I did not mix up the red wire with some other red wire, I took off the EMS back connector and powered the unit with power and ground discrete leads using crimp sockets to slide on the pins of the unit's connectors. I then checked the power output pin for the fuel flow sensor (pin 15). It read zero volts. Interestingly enough the signal pin (pin 14) read ~4 volts. Note in all this testing I had the sender unit disconnected.
Am I missing something?
