Fluid Temp Sensors
DWS
Per the Dynon catalog, P/N 100409-000 is described as: Oil Temperature, 1/8-27 NPT , Continental 0-200
and
P/N 100409-001 is described as: Oil Temperature, 5/8-18 UNF, Lycoming/Superior/Continental
The Sensor Definition File has the part numbers switched.
id=1/8"-27 NPT FLUID TEMP (100409-001)
id=5/8"-18 NPT FLUID TEMP (100409-000)
I need a sensor with 1/8-27 NPT thread. Which part number do I order and which sensor definition do I use? Thank you.
DWS:
The catalog description and P/N is correct, so order P/N 100409-000.
You apparently have an older version of SkyView software and/or EMS Sensor Definitions file. As of v10.0, SkyViewEMS SETUP > SENSOR INPUT MAPPING has the correct description and P/N - suggest you use Method 1 download to update both.
and
