FT-60
pgtuck
FT-60 K factor changes do not change the indicated flow. True fuel output is higher than what is displayed on HDX. I have adjusted the K factor from 68000 to higher number in hopes of matching displayed value to actual output. No joy! All help is appreciated. Thanks!
GKC Aviation
There is a simple fuel flow K-Factor formula that I got from Garmin G3X install manual.
Reported fuel used, times previous K-Factor (the K-factor in the system now), divided by actual fuel used.
For example, if the EMS tells you that you used 20 litres, but you refill the tank and find you actually burned 25 litres, and your K-Factor is 68000, then:
20 times 68000 equals 1,360,000
Divided by 25 equals 54,400 your new K-Factor.
When you do these checks, it is best to start will full tanks, then after an hour or so flying note the fuel used by the EMS, and then fill your tanks back to the top and note that amount. It is usually very close after one adjustment, and extremely good after two.
For example, if after the above adjustment of the K-Factor you go fly again, and the EMS says you burned 25 litres, but you refill the tank and find you actually burned 26 litres:
25 X 54,400 divided by 26
= 52307
Give this a go. If I have made a mathematical stuff up, it's because it is very early in the morning and I haven't had enough coffee.
  • Like
Reactions: RAS
I'll add to the above that, the larger the amount of fuel burned and pumped the more accurate the adjustment will be. Pump the fuel yourself where you can visually see the level and make sure it is at the same place both times, rather than letting a lineboy do it, to make certain the amount of fuel pumped to replace the amount burned is accurate.
pgtuck
Thanks for the great info! My interest is a bit different. My fuel flow reading on the panel reads .2gal/hr without engine running. How do I make this zero. I have adjusted K value from one extreme to the other. No change.
looks like an issue other than the K factor - I’d contact Electronics International direct (give them the serial number of the FT-60) & explain the issue you have. Ive never heard, on any forum, of a reading without engine running. Hope it gets sorted for you 😉.
