jwachman
Firstly, I have worked through the forum site and can't find a reference to my exact issue, hence I am adding my own post.
Configuration. EMS D-10, EFIS D-10A and HS34. All running version 5.0, and woking fine on the DSAB. Main tanks connected to EMS, Tank 3 & 4 connected to HS34.
HS 34 tank connections function, and the sensors register, but I keep having problems.
All tanks are 40 ltrs, all have identical sensors.
The main tanks are calibrated correctly, and during the calibration I noted the sensors start at a reading of about 135 and reduce at about 15 intervals to finally read about 30. Each addition of 5 ltrs calibrates successfully, and there are no bumps in the calibration.
Now on to the tank 3 & 4 problems. The HS34 is correctly connected and the 1K resistors are fitted and connected to the 5V exciter line. (This had been the problem in a previous post of mine).
However, when I run the calibration the sensor initially reads about 35, and drops 2-3 with each addition of 5 ltrs. Each time I add 5 ltrs the calibration states "no fuel was added, did you want to accept this reading" (or similar words), I select Yes. This happens for each addition of 5 ltrs. Eventually, I fill the tank and select full. The calibration says that it works, but when I next apply power, the tanks have CAL above them, and need re-calibrating.
It appears the issue is related to the fact the sensor only reads 35 to 5, not 135 down to 40, as per the main tanks connected to the EMS.
I can't understand why the input via the HS34 doesn't function the same as the main tank.
Can you please assist. I have completed all the fault inding I can.
Many thanks.
Jon :-/
Many thanks.
Jon :-/
