My skyview indicates fluctuating fuel flow at steady state cruise. I have an RV7 with a Lycoming IO360. The fuel flow sender is an EI FT-60 "Red Cube" mounted in the vertical portion of the fuel line between the fuel injector servo and the "spider". At steady state cruise it continually fluctuates between 10 and 19 gph. It should be reading around 8.5gph. It has done this since the first flight. Is there a way to check the sender myself or do I need to send it to the manufacturer?
