Yes. There is a setting that you'll need to change manually: ff_policy=single. You'll need to add this line to a file ending in .dfg, and then load it into SkyView. In this mode, you can use SkyView's two flow inputs to have independent flow gauges (instead of the normal subtraction scheme for engines with a return flow line).
