fly4fn
Question regarding fuel flow calibration. I am running an automotive conversion that is fuel injected. This fuel system is a continuous flow type with 2 flow transducers installed. While adjusting the flow transducers per the Dynon installation guide pg 7-65, (fuel used computed divided by fuel filled actual) is this number to be used to adjust both transducers or just one? During initial setup I would run the fuel pumps and adjust only one of the transducers until I obtained a flow of "zero" since I was not "using" any fuel as the engine was not running. This made sense, but I see nothing about this step in the Dynon guide.
Kevin Metzler
Velocity 133SV
Kevin Metzler
Velocity 133SV
