fuel guages on the dynon
brucec
I have the 7 inch screen for flight instruments only and I would like to use fuel gauges on the screen  I have went in and set it up with 20% for fuel gauges only removing all other engine gauges. But can not get it to display the fuel gauges on the main page it shows the red x across the page.
There are a few things here that aren't configured correctly. It's possible that your EMS module and/or SkyView Network isn't fully configured (there's almost certainly a configuration issue if you're seeing a red X on the whole display), or it could be that you don't have the EMS page pulled up (under the SCREEN menu). Can you take a picture of what you're seeing and email it to support at dynonavionics dot com?
Followup - we talked with brucec in Tech Support, and explained that to monitor fuel levels, the SkyView system had to have a SV-EMS-220.
