rfazio1951
- Joined
- Feb 11, 2010
- Messages
- 355
I calibrated the two fuel tanks in my RV-6, and then like a dummy I reloaded the sensors.sfg file after I made changes to it and lost my fuel level calibration. So I recalibarated the tanks again today. The first time I did it The left tank got to 8 gallons and told me the value did not change and I confirmed it. After that I filled it the rest of the way and I got a reading that would go to 7 gallons then 7+ when over 7. The right tank because the sender is in a different place worked well up to 18 gallons then showed 18+. I thought this was ok cause the left tank sender is all the way inboard and gets pinned when the tank is not full, Today after starting over the left tank went to 12 before it wouldn't go any higher. I thought, good maybe it was a good thing that I messed up and had to recalibrate. I got better settings and it went to 12 then 12+. But then when I went to do the right tank it just stopped at 12 and said I was done? Even though the numbers were still changing? Why did it stop? I would much rather have the 18+ gallons on the right I got the first time. I know you are going to tell me I have to do the right tank over again.
