fuel level(s) indicator - bar me not...
pksgwfac6v
Setting up my EMS I discovered the fuel level(s) is not available in the 270 degree sweep gauge like my other indicators. Why not? Can it be made available instead of the bar indicator? Undecided
Currently, there's no way to do it without editing an exported configuration file and tweaking it by hand (and is fairly obvious if you're a bit technical once you crack open the file). So if you're adventurous type, just remember to save a backup of what you started with before you edit a second copy of the EMS configuration file.
We'll look into reducing that restriction in a future release, but it will probably be a while.
pksgwfac6v
OK then, how abt this: I have a 0 to 5 volt fuel level sensor (capacitance with a voltage converter built in). Can I use a general purpose input(s) and design my own 270 degree widget? ;D
