f5ftiger
Hi,
I have a D-180 connected to the 24 Volt main Avionic bus. Then I have a 12 Volt Skysport Capacity type fuel sender with gage connected to an linear voltage convertor... that all works perfect so far!
When I hook up the D-180 fuel tank 1 input to the Skysport sender the the CHT temp drops down to -99 and the OAT drops to -9... and the ManPress rises :'(
That is strange! or?
if I see it right what is the problem, the sender output is somewhere 0-5V! Sender type is right...
EMS, fuel level gage, sender and voltage converter share the same ground!
Do I have to remove the gage?
Do I need a different sender powerd by 24v?
PLEASE HELP!![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
PLEASE HELP!
