fuel pressure alert
romeo219
I  have SV-D1000 10" whith Rotax engine type 912- uls2    the problem is  that I get fuel pressure alerts, at the past i got  warnings of low fuel pressure  checked the fuel pressure with a mechanical analog gauge and it was fine so we changed the fuel pressure transmitter  after replacing the pressure transmitter  I now get a warning of high pressure, I want to emphasize that alerts of  the fuel pressure are only some of the time and not  all the time, Is it possible that the problem is in your system
Generically, no, it's not likely to be a problem with the system. Are you using the Kavlico sensors or the older mechanical style ones? The Kavlico sensors are a big improvement. They're both more reliable over the long term and have better precision/accuracy, period.
